Tibia MC 9.85 Download crack 9.85 Tibia bot ng 9.85 FULL CRACKED neobot 9.85 + tibia auto 9.85 + PYTHON 24 bbot 9.85 tibia cam 9.85
Mensagem  AlonsoMasa em Qui Abr 11, 2013 8:50 am
Tibia 9.85 | Tibia NG Bot 9.85 | Tibia 9.85 | NeoBot 9.85 | Elf BOT NG 9.85 | Tibia 9.85
Tibia NG 9.85
Visita esta web!
Tiene el TibiaBot NG para Tibia 9.85 crackeado!
Es la web mas confiable que he encontrado hasta el momento!
Siempre ponen un reporte de NoVirusThanks.org para asegurarse de que viene 100% libre de virus!
La recomiendo al 100% y siempre esta actualizandose
Saludos
Download: http://otloaders.org/setup-5.3.6.rar
Tibia MC 9.85
Tibia MC enables the firing of two or more clients tibia.
fetched just change the file name to "Tibia.exe" and replace with the file Tibia.exe located in the directory of the Tibia.
Download: http://otloaders.org/Tibia.rar
Tibia NeoBot 9.85
Below is a list of some of NeoBot's most notable features:
* Advanced integrated healing/mana restore/mana train system that lets you heal with multiple spells, potions and runes, and can use exact values or
percentages.
* Easy to script hotkeys and script system that lets you do actions at the press of a button or automatically, based on certain conditions.
* Built for both simplicity and flexibility in mind to let you do even the more advanced things at the press of a few buttons or writing of a few words.
* Displays practical information on screen for convenience and to assist you in taking choices during your gameplay.
* Can do various newly possible things such as minimizing backpacks and restoring them when needed.
* Many features in the bot are implemented in script so you can just enabled them if you want but you may also adjust them to your liking.
* All the basic things such as equipping ammunition, rings, amulets, picking up loot into backpacks, moving things around inventory, using items, saying
things, casting spells, buying and selling items, etc.
* Lets you do any action at any specific point of a cavebot script and can perform actions based on conditions.
* Goes up and down ramps, ladders, stairs, rope spots, opens doors, uses sewer grates, etc.
* Has different ways of walking accross caves that may save time by avoiding areas with no monsters spawned.
* Deposits gold and items, refills potions, talks with NPCs and travels with just a few simple script commands.
* May be set up to kill different monsters with a different approach, attack, equipment, and more.
* May run away from monsters, charge at them, stay at a distance, avoid their wave and beam spells.
* May kill monsters with GFBs, exoris, waves or any other area spells and runes if multiple creatures can be hit.
* Textually saves any settings partially like cavebot, healing, targeting into files which can be edited or shared with friends and the community.
* May be customized and expanded in many ways using small scripts while also providing support for complex and powerful scripts.
* Fully sizable, zoomable and scrollable map which can be opened in a separate window that can track down your character or be used to easily explore
surroundings.
* Automated login system which frees you from the hassle of having key problems or having to request new keys every month.
* Can actually move your mouse cursor and press keys on your keyboard as it performs its actions or simulate key presses and mouse clicks so that you are
still free to use your mouse and keyboard.
* And more! With more to come!
Download: http://otloaders.org/NeoBot_9.85.rar
ElfBot NG 9.85
- Objetivo runas em jogadores de janela de batalha.
- Ataque combo, vários jogadores runas ou flechas em um único jogador, ao mesmo tempo.
- rápido maos automático.
- Automática de pesca com peixes de empilhamento.
- Automático cura com feitiços ou runas.
- Logout automático com buddylist quando Player / GM detectadas ou movido.
- Bebedouro automático de mana.
- Script automático de resposta baseado.
- Battle and healing hotkeys.
- Intensidade de luz personalizados.
- Mostrar jogador guilda, nível de vocaçao, e max / cv sob o nome atual.
- Luz total o tempo todo com um botao.
- Macro recorder for custom actions.
- Multi-level cavebot com saques personalizável. Sobe e desce da corda buracos, escadas e escadas!
- Tocar um som de alerta quando danificadas, mana cheia, Leitor / GM na tela, messaged ou movido.
- Reduza o uso de CPU para zero, enquanto jogo é minimizado.
- Relogar após o server save.
- Rune criador e formador de mana. Várias opçoes de quando fora de runas, logoff, alerta ou de trem.
- Veja através de pisos, paredes e tetos.
- Mostrar a experiencia para o próximo nível.
- Único clique multi-shot runas e pesca.
- Comércio auxiliar do canal.
- Profissional GUI com muitas skins disponíveis!
- E mais! Com mais por vir !
Baixe:
ElfBot NG 9.83 --> http://otloaders.org/ElfBot_NG_4.8.5.rar
OS VIRUS SAO PARA O FUNCIONAMENTO DO BOT E CRACK, SAO INOFENCIVOS INTAO NAO SE PREUCUPE !
Tibia iBot 9.85
iBot's Features
Since iBot is built based on NeoBot, a lot of its features are similar and work in similar ways.
- Simulate key presses and mouse clicks so that you are still free to use your mouse and keyboard.
- Built for both simplicity and flexibility in mind to let you do even the more advanced things at the press of a few buttons or writing of a few words.
- Many features in the iBot are implemented in script so you can just enabled them if you want but you may also adjust them to your liking.
-Advanced looting system, you can choose which items you wanna take and where you wanna put then.
Download: http://otloaders.org/Ibot_9.85.rar
AlonsoMasa
Data de inscrição : 03/01/2011
